Black smoke when warming up the car
Creative
Hi there, my engine 4g92p have some problem recently, when the engine is cold, i start the car and the engine start to vibrate and black smoke comes out from the exhaust, after 30 seconds or 1 minute the engine back to normal and no more smoke, but then sometimes while driving at lower rpm it jerks abit, if i stop the engine and start again when the engine is warm it starts fine, i've sent to few mechanics and they also having hard time to find the problem, i've changed spark plug, tried to change the spark plug cable and distributor, changed the fuel injector and the problem still there, hope someone can help me thank you.
either the cold start valve is out, or its need to be retuned sir
---------- Post added at 07:30 PM ---------- 6 hour anti-bump limit - Previous post was at 07:28 PM ----------
ohh, and is the thermostat still in? how is it?
i guess the thermostat is still in there. guess it is fine, just that when i start .. it feels like 1 spark plug not working..
The errors are
12. VAF CIRCUIT
55. IAC VALVE POSITION SENSOR
25. BARO CIRCUIT
So most probably my MAF gone? do i need to change it or can just service it?
The errors are
12. VAF CIRCUIT
25. BARO CIRCUIT
for IAC(Idle Air Control)...try to clean n resetting this sensor.....if after tried, it still appeared as error code. mean the sensor need replacement.
and clean also ur maf/map sensor....
