Link G4+ Atom
Link G4+ Atom
amr_chev
Spec[/U];
•Four injector drives
•Four ignition outputs
•Three analog inputs (you can choose from sensors like oil pressure, fuel pressure etc)
•Two temperature inputs (e.g. water and inlet air temp)
•Two digital inputs (e.g. vehicle speed and logging switch)
•Four auxiliary outputs (e.g. fuel pump, fans, boost control)
•One, thirty four pin, waterproof automotive connector
•5V out
•The same tuning features as Links high-end ECUs – Tuning with PCLink
•Fully configurable – no preset input or outputs
•Logging and OBDII upgrades available
•Closed loop fuel and ethanol compensation if external devices are added
-ecu unit
-bracket
-usb cable
-short loom
