Audison Bit One Signal Processor
ICE -In Car Entertainment
chuppingaudio
The bit One is a multi-function digital processor capable of interfacing with any analog and/or digital source, turning any ordinary system into one with very high-level performance.
Despite its compact size, the bit One is equipped with a powerful, latest generation 266 MHz / 32 bit floating point DSP microprocessor, working in real time on all the functions of the most complete systems.
Managed and configured by a simple and intuitive computer software, it is possible to make adjustments to improve the signal through each phase of its path; from input to output.
Specifications
Inputs
8 independent high-level channels or 6 independent analog low-level channels
2 analog low-level stereo auxiliary inputs
1 optical digital input
1 electric coaxial digital input
1 high-level momentary audio interrupt input (with Mute IN) for use with mobile phone or navigation systems
Outputs
8 independent low-level analog channels and 1 AD Link output
(8 independent digital audio channels through a single CAT 5.S LAN cable for use with AD Link provided amplifiers)
Connections
1 USB /B (2.0) connector for PC connection
2 AC Link control bus connectors for DRC and AC Link amplifiers
System
Full range stereo or multichannel signal derived through automatic summing of up to eight high level inputs
Configuration
Guided procedure to assign input channels to selected output channels based on inputs, speaker and amplifier configuration
If necessary, Bit One creates a rear, subwoofer and center channel output (mixed L+R) from a single stereo input
In/Out Volume
Input sensitivity automatically adjusted for the main inputs (with supplied Test CD and DVD)
Manual input sensitivity adjustment for auxiliary inputs
Independent level control for each output channel for system fine tuning (-40 ÷ 0 dB)
Equalizer
Dynamic equalizer: system self-adjusts between low and high listening levels
Automatic de-equalization of signal fed into the high-level inputs
Four separate 31-band graphic equalizers (1/3 Oct.; ±12dB) for each auxiliary inputs
Eight independent 31-band graphic equalizers (1/3 Oct.; ±12dB) for each of the eight output channels
Crossover
Filter Filter typology: Selectable; Hi-pass, Lo-pass, Bandpass, Full Range
Cut-off frequency: 70 steps available from 10Hz to 20kHz
Cut-off slope: Selectable; 6 to 48 dB/Oct.
Alignments: Selectable; Linkwitz or Butterworth
Mute: Selectable for each output (On/Off)
Phase: Selectable for each output (0°/180°)
Time Alignment
Guided procedure for the inputting of speaker distance with an automated calculation of proper delay times for each channel for accurate time alignment set-up.
System also provides for manual fine tuning of delay.
DRC
Master Volume control, Subwoofer Volume control, Balance control, Fader control, Input selection, Memory selection, Dynamic Equalizer On/Off
Memory
4 presets separately managed and recalled from the DRC Remote Control
Standard Mode
Simplified management of crossover and equalization functions for expedient set-up and use
Expert Mode
Full management of crossover and equalization functions
for full reference grade system tuning
****NO CD or software
Includes Cables,include
1. box
2. cables (4 nos)
3. display unit
4. audison bit one
Good working before dekitting
Price: rmSOLD
Postage fees by buyer
Call / WhatsApp to deal 0197304525 or by whatsApp for more details and photos
Check out more goods at other ads & fb @ck chupping
Payment option:
- Cash On Delivery
- Online Payment/Postage:
postage can be arrange
