L2 turbo blow valve leak engine oil
kidda21
hi, i own a L2 kancil but there is engine oil leaks out from blow valve, as i been told is the turbo spoil ady. looking to replace with a L5 turbo.
I heard that those L2 and L5 turbo are quiet easy to breakdown. Are this true??? Please Advise.
And i do heard that some modification need to be done to the turbo, which make the hole bigger for more engine oil to flow in. Does it true???
Hope sifu-sifu here can help.
Thanks a lot
:idea: check the breeder hole on the block , turbo return line n valve cover breeder for blockage.....detail job pls! n make sure e.oil level just below full line. this matter is to confirm turbo leak! if ez to break down u can get it after all this year. Take care the e.oil n try not to over boost it max 0.7bar, use a soft blow valve(example: std spring load type:biggrin) to protect it
hope this help!
:listen:eterna twin turbo is quiet good result n cheap:cheers:
