K3-VET piston suitable K3-VE
No to sure about the con rods though but the piston is definitely PnP, as in no mod need to be done if you wanna use the YRV piston ;)
ej-ve shld be able to fit 72mm as stock size also 72mm if not mistaken
u using it for BOT purposes? ?
im also driving viva 1.0 :)
other then nissan march 73mm pistons..
what other pistons can fit, plug and play into ej-ve..
problem now is piston cracked, now found yrv k3-vet brand new 72mm..
in case mechanic call say need to rebore, have to turun 73mm..
