K3-VE engine with YRV Tiptronic GB?
the tiptronic is controlled by the YRV ECU+TCU.
YRV wiring is 'terbalik' with Myvi.
unless you use back YRV's ECU+TCU. otherwise won't work. YRV ECU is for turbo..so it won't work for your K3-VE engine anyway.
EDIT: Actually it might be possible if you can send the necessary signal from the MYVI ECU to YRV TCU, I believe its speed and rpm.
