K&N Apollo Universal Closed Intake Systems
powerautohauz
((( God Level 30,000 RPM )))
The K&N Apollo CIS (Closed Intake System) is a universal air intake system incorporating a washable/reusable K&N High-Flow Air Filter. The Apollo’s specially designed shape increases volumetric efficiency and provides the benefits of an open cone filter and standard air box in one unit. Heat build up is reduced which keeps the intake charge cool. Smooth internal features minimize air turbulence and maximize air flow.
The Apollo's outer shell is made of a durable lightweight material that helps keep incoming air cool as it enters the engine chamber. K&N's Apollo system includes a cold air hose with a specially designed radius end cap so cooler outside air can be directed into the engine. The Apollo has a 70mm base flange. It is supplied with a pack of vent adapters to incorporate most engine breathers and temperature sensors from the original air box assembly back into the Apollo. Included vent sizes are ¼” outside diameter, 3/8” outside diameter, ½” outside diameter, 5/8” outside diameter and a blanking plug if a vent adapter is not required.
The Apollo is ideal for normally aspired engines up to 250BHP and turbo engines up to 350BHP. It allows for updating your intake system while retaining a closed environment.
Product Specifications:
Product Style: Unique Universal Air Filter
Filter Material: Cotton Gauze
Flanges: None
Height: 4.875 in (124 mm)
Clamp Style: No Clamps Required
Replacement Filter: RC-5052
Weight: 2.5 lb (1.2 kg)
Product Box Length: 9.1 in (231 mm)
Product Box Width: 9.2 in (234 mm)
Product Box Height: 9.4 in (239 mm)
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
Desmond 017-396 8567
Email us : [email protected]
