K&N Apollo Closed Induction Kit
holydevil
The new K&N Apollo Cold Air Induction Systems incorporate a washable/reusable K&N High-Flow Air Filter within a protective shell. This shell reduces heat build-up and feeds cool air into your engine, resulting in more cold air for increased power gains. Unlike the Typhoon kits which the Apollo kit does not take air from around the filter which can be hot, the intake pipe is connected to the filter casing so that only cold air from outside of the hot engine bay is used. The colder the air, the more power the engine produces.
Apollo Cold Air Induction Systems overcome the problems of heat soak which can often be associated with open induction kits.
Because of the enclosed design of the Apollo kit, they do not tend to give an induction noise as loud as the Typhoon kits, but they do give excellent power increases.
Contact us: (Call/whatsapp)
Hunting line: +6012 879 4422
Brunei payment line +673 720 6634
Email: [email protected] www.hdmsauto.com
(provide delivery nationwide/singapore/brunei)
HDmotorsports | Facebook
