Izzit possible to add a Turbo Kit on normal engine
lorddie
Hi,guys,i am newbie here,i just wanna ask,izzit posible i add on turbo kit to my stock engine. My engine is Toyota 3S-FE engine, 2000 cc. can i know wat part do i need and where can i find it,thanks a lot
with money.. anything is possible... using 3S-FE? why dun u get half-cut 3S-GTE? stock turbo already ... i think less den RM4000 for the half-cut.. happy hunting.
erm... i also got think of 3S-GTE,but i afraid will make more work to fix that engine into my car.. i still considering which one better,add turbo kit or half cut 3S-GTE
i think half cut better...coz the engine internal is made to witstand turbo force induction...
compare 2 ur stock engine...i think u can go 4 big sum of boost...
i think even proton 1.5 will run ok wit a turbo kit wit juz 0.3-0.5 bar of boost...doesnt need intercooler...but...better dump in GSR rite...
anyway...it juz my 2 cent...
just a important question to ask u all..
is there a difference between a twin cam 1.8 block and a sohc 1.8 block?
just wondering
cheers
phil
things you should haf for a turbo kit:
exhaust manifold
turbocharger
wastegate
downpipe
intercooler(depending on ur boost level)
piping
BOV
oil system
fuel system
ignition system
ignition and fuek control (engine management)
boost controller
things u need for a half cut:
cash
time
so..by that info you should see the obvious matter about bolting a turbo kit on.so much of money will be spent on ur engine and by this its going to reduce your engine's lifespan.
going for a halfcut would be so much better.
just wondering
cheers
phil
the valve performance will be better.
Originally posted by L2TurboFool+Jan 31 2005, 14:58 -->
QUOTE (L2TurboFool @ Jan 31 2005, 14:58 )
--QuoteBegin-philipplim
@Jan 31 2005, 14:10
just wondering
cheers
phil
the valve performance will be better. [/b][/quote]
u r not reading the question correctly i presume.. from what i heard, there is no difference what so ever.. even refer to 4G9x manual also didnt see any difference.. but never realy check the real thing laa
exhaust manifold
turbocharger
wastegate
downpipe
piping
BOV
oil system
fuel system
ignition system
boost controller
cash
time
Thanks,i think i will go for half cut,coz i already ask my friend bout 3S-GTe half cut,celica,include MR2 gear box,about 2k ++.so,i think i will wait for the half cut,thanks a lot,by the way,wanna ask,wat mean by the Bar ... for turbo??sorry,noob here
Originally posted by tajulsans+Jan 31 2005, 15:28 -->
QUOTE (tajulsans @ Jan 31 2005, 15:28 )
@Jan 31 2005, 14:10
just wondering
cheers
phil
u r not reading the question correctly i presume.. from what i heard, there is no difference what so ever.. even refer to 4G9x manual also didnt see any difference.. but never realy check the real thing laa [/b][/quote]
hhrmm...ne1 here done a convertion like that?care to xplain?
better choice! ;)
bar is the unit that your boost preassure is measured in. bar/psi.
i still working on mod my car,toyota Corona St171, i just finish some body work only,this car last time belong to my dad one,now he gave me,so i wanna mod it kao kao one,the 3S-GTE,i order ler,left the body part,i plan to add on a rear wing ,any suggestion??
to cut cost, u can use 3SGTE piston with thick head gasket.
without thick head gasket the compression wont drop, cos FE head compression chamber is small, compare to GE..
