Iswara@saga Adjustable
GAB, HWL, TITAN, IMPROVE, etc...
mostly jz high/low adjustable... cannot adjust damping rate...
and rear suspension setup usually not high/low adjustable...
hence, what u get is jz front pair height adjustable...
apm motorsport also got bro.but like sky bro said.all of them r just hi/lo adj.
not to mention the rear is fix unlike myvi which gab n hwl came out with
rear adj too.
of all mentioned above, TITAN is the most expensive, isnt it?
Read that u gotta go back to their workshop, and adjust spring rates/height till u r satisfied...
Assuming a person is located far away like in Sarawak or Sabah, who do not have the privilege of going to the workshop (TITAN ka, HWL ka), which would be the more suitable set of abs that already comes with spring rates more suited for the general driver?
Get a HWL front adjustable hi-lo, get the correct spring n damping rate. Then customize the right absorber n match the correct spring rate for rear suspension.
Then correct your centre gravity balance by adjusting the front height (this could means that your nose is slightly taller than your tail)
Then get 15" rims with GOOD tyres (yoko for example)
Then, MAYBE your saga can pek corner at 110kmh downhill kerinchi link....
All this setup are done on my nissan, u can try it out on your saga :driver:
Ofcoz, the real purpose of Hi-Lo is to correct your weight shifting during cornering, since saga can only play with front hi-lo, u need time to tune it to the correct handling according to your driving style.
Janji DONT make your backside jongkek like those rally-wannabe....:rofl:
den u'll have to get preset adjustables lor... or send ur car over for a month or so for complete tune up... head down to sepang for a few round as well... hehehehe....
yeap... high/low adjustables are not mainly for looks.... its main purpose is for weight distribution... if front is lower than rear, ur front sits more weight compare to rear... all this need to calculate nicely to have a perfect 50:50 weight distribution to have good handling... well, not exactly 50:50 is good for all cars lah... different cars with different drivetrain might need different weight distribution....
hmm...i see i see, tenks 4 all info
when i do plan to get a set, i dont really want to gamble on the spring rates, guess i gotta go with the most widely-used spring rate setup instead
wah send car there ar...hehe lu sponsor then can :P
If u play with hard absorber, then you got highway handling.
If u play with hard springs, u get very good handling but terrible ride quality.
If u get FULLY adjustable, u can tune to comfort in weekdays, tune to extreme in weekend to play around.
Hi-Lo only contribute to balancing your car, enhancing your cornering and braking grip, but its cant do more than that, so expectation is a slighly better handling but not there yet.
I personally is going for TEIN fully adjustable :)
I said all these so coz I am using HWL Hi-Lo now, a very good street setting and highway setting, but cornering still not that good enough
Anyway, for additional tips.
Once you change your suspension setup, plz change to a bucket seat, a seat you can feel your car balance and grip with your butt, you shoulders and you thighs.
Try normal speed entering a corner, then 2nd time same corner, push abit, and harder, then harder more n so on n so forth.
Find your grip, does it under or over most time......use your body to feel the seat n the G-force.
Then try this too, when in highway, cruise at least 80kmh n zig-zag HARSHLY (when the road is clear ofcoz!) Then try to feel how much your rear suspension bounce, does the tyre grip loses it's traction, and how much movement your tail occurs in the jerk.
From there, when you tweak your rear suspension again (in any method you can try) then you try again, you WILL see the difference.
Lets talk about some basic Hi-Lo setting.
Sohai proton rally-wannabe style
- Actually this setting can be very good, it pushes most the weight to the FRONT, hence the 0-100kmh is quite good since the front tyres gets all the grip.
- If you try zig-zag hashly, you will realise the rear will lose traction easily, dangerous for a normal driver n car stability hard to predict
- But this setting is GOOD for autoX, since it has good front grip and loose rear traction
Nose up, Tail Down
- This may sound ridiculous, but actually you cant differenciate with your naked eye
- Zig-zag test shows that the car is will balanced, the rear grips back immediately after minor traction loss
- Highway corner, at 160kmh the rear grip very very well, coz the wieght is tranfer to the back, as well as the aerodynamics is keep your nose down, you DONT even need a bodykit!
FINALLY, for Hi-Lo, the most crucial thing for performance n comfort, is to balance the car playing the ride hieght of front n back, and also harder absorber rate will help too.
Happy tryings:wavey:
Nose up, Tail Down
sounds like many many much work....i guess with adjustables with varying settings, got no choice...
Nop, TITANS are the best adjustables for saga/iswara...very reputable
very good....as you will find out....hohoho :driver:
Soon, soon. I made sure it won't be soft, that's for sure. They pull some strings with their regular suspension supplier to custom made the rear springs as a 'once-off' unit to match with the Titans. I was so carried away with the conversation, I forgot to ask him "What about future replacements ?" heh
nvmlah, you got quite a few yrs b4 worrying about that...but then...hehhe yeah you shud've asked, ballpark figure for the cost?
Im more leaning towards HWL actually now, cost-wise, quite ok...read that durability is pretty ok, which is one big + sign for me
I dont want to ship back the absorbers...hafta go across the ocean quite sien le :P
They told me the cost before committing. I think the spring is 2.65kg/f
ECU already fully wired. I get a feeling that they have a fair idea but not absolutely 100% sure what to expect because they suggested to let's wait and see how much horses it churns out at the wheels before considering if a better LSD is necessary. I actually been offerred another version of their LSD just in case it's needed. You see the guy I told you about, the same fella I am corresponding with....they fitted a similar setup into his car and he's getting wheelspin all the way to 3rd gear... lol
Keep me updated on those HWL
