some question bout hi cam
mika_mivec
hey guys,juz want to know,what are the valve clearence in installing hi cam into 4g13/15 inj?is it neccessary to change valve valve spring timing belt?and how to setting the adj cam pulley for single cam?i mean the max we can adjust whether advance or retard:hmmmm:hope to all sifu2 in zth can help :driver:
*piper or jasma cam shaft
*arospeed adj cam pulley
hot engine:
inlet 0.15mm
exhaust 0.25mm
normal regrind cams not necessary to change valve spring
old skool tuning,
u can start with stock cam timing setting.. slowly retard the cam by each mark... test drive and check ur preference...
proper tuning,
need to use dial gauge and proper calculation on cam timing with respect to opening of intake and exhaust valve...
hot engine:
inlet 0.15mm
exhaust 0.25mm
old skool tuning,
proper tuning,
sifu sky, wat is a dial gauge and proper calculation?
