Installing Water Temp gauge
RB26
GoKart Lover
Hi fellow ZTHian, i have currently bought a water temp meter, but no idea on the wiring part,hope sifu can show me some guide:
I have the sensor install and go thru firewall
http://mangoesteen.net/download/iswara-water-temp-gauge-install-1.jpg
red, black, white n yellow wire
http://mangoesteen.net/download/iswara-water-temp-gauge-install-2.jpg
have check the under neadth of the dashboard, not sure how to tarik the wiring for 12V? can i sambung from the fusebox? how? :stars:
http://mangoesteen.net/download/iswara-water-temp-gauge-install-3.jpg
http://mangoesteen.net/download/iswara-water-temp-gauge-install-4.jpg
Red should be 12v
Black should be Ground
Yellow & white is sensor
If sensor already fix just tap 12v from keys. Normally 12v wire is red colour.
ya but from the picture, got a lot red wire...got think got thin.....how to figure out..?:bawling:
u can tap from fuse that labelled as "clock" oso...since clock working only when ignition switched on....check the position by reffering to the fuse cover....anything that work when u switched on the ignition would do the same job....
thanks, manage to get it work:
http://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash4/196555_134769976593438_100001813102793_213663_1139958_n.jpg
but i not able to find the lamp light, so day time and night time same light :hmmmm:, do you know where can get the lamp wire? is it Radio and cigratte light there got this wire?
ciggarate lighter port got light bulb/socket behind it....if u lazy to open dashboard center panel..then u try look for RH/LH light fuse socket at fusebox in the engine bay....
