Gauges installation.
skyline2778
Hi guys,
Well just wanted to know something....i m drivin a iswara a/b 1.3 carbie.Planning to install some meters.If i m installing a oil pressure gauge,water temp or oil temp gauge,how actually would their install it on my car.I mean,do they need to drill or do any modification on the engine? Anybody can explain the process for me?Thanks. :wink:
:dancing2:
just send u'r car 2 the acc. shop maaa....
easy......
they'll do everythings 4 u....
bring along the 'kepala agong' notes...
heheheee
sure they'll like u ...
:dancing2:
Hahaha....yeah,they will damn happy one.....
Actually i m not planning to install by myself.Just wanted to know the process.....actually they r charging high rates for installations. :biggrin:
how much they charge you on the installation?? what brand u plan to put brother ?? ... these days are very dangerous with gauges ... better think before you do it ... Cheers
zakie said:
yaaa looorrr..
how much r they charging u per meter installation??
story laaa....
:dancing2:
actually it may vary from the shop you go ... it is from either rm30 to 70-80 per piece ... depends on the meter as well ... some meter very easy can DIY ... but some are slightly more to do ... so better find a good shop ... =) Cheers
RM80 to install water temp, oil temp or oil pressure is standard workmanship charges.
-some cars need oil adapter (known as sandwich plate) to install oil temp and press- that adapter alone cost RM180 liao... if they quoted you RM80 for everything... den it is not expensive... within market price.
Vacuum & Volt only RM30.00 (for both meters)
