Y YEN96 Known Member Nov 22, 2014 #1 How to check idle air control valve working..the one mount at intake manifold. hear say can bypass this valve ??? Need to connect or bypass Oslo ok.??
T TrailBlazer69 Active Member Nov 8, 2015 #2 disconnect ur IACV wire/ sensor...if the car stall then ur IACV is working fine. If its not then its the vice versa.
