Works Engineering Racing Blow Off Valve
Works
www.worksengineering.co
WORKS ENGINEERING BLOW OFF VALVE
http://www.zerotohundred.com/newforums/picture.php?albumid=2840&pictureid=11044
Blow off valve (BOV), bypass valve or dump valve is a pressure release system present in most turbocharged engines. Its purpose is to prevent compressor surge, and reduce wear on the turbocharger and engine. Blowoff valves relieve the damaging effects of compressor "surge loading" by allowing the compressed air to vent to the atmosphere, making a distinct hissing sound, or recirculate into the intake upstream of the compressor inlet.
A blow off valve is connected by a vacuum hose to the intake manifold after the throttle plate. When the throttle is closed, the relative manifold pressure drops below atmospheric pressure and the resulting pressure differential operates the blow off valve's piston. The excess pressure from the turbocharger is then vented into the atmosphere or recirculated into the intake upstream of the compressor inlet.
Get your FREE shipping when you purchase at our Online Store
RACING BLOW OFF VALVE
Shop Location :
36,JLN PJS 11/7
Bandar Sunway
46150 Petaling Jaya
Mon - Sat
9.30am to 6.30pm
CALL ME NOW @ 016-229 9610 (Whatsapp / Wechat )
