i need HELP !! T.T
peterj
i just open up my e4 engine today..... looks like luck always not by my side..... my block being scratch by the piston, make the engine damaged, even got suspected head lifting cause we open the head so easy, not tight at all..... i got 1 RVR engine, terbalik type, it looks similar to my e4 engine, i plan to use that engine, my problem is
- i know the rvr different from e4 engine in turbo, injector, valve cover colour,ecu and wiring, and also intake.... what more different?? can anyone help me? will that engine have similar or same output if i change my injector, turbo,intakes,ecu to it??:bawling::bawling::bawling:
Danz, speed2horizon, jin, xtreameleo:bawling::bawling: save my ride:bawling::bawling: any ZTH brothers, pls help also:bawling::bawling:
yeah2 betul, rebore an extra 2mm of your original pistons....
my block also calar abit, i just change the piston rings...wattudu, cannot afford new pistons for the time being......
