How to remove PV6 front bumper?
Omnipotent
Hi all, i'm planning on to retrofit my Perdana V6 headlamps but it seems that I need to remove my bumper to get the headlights out...anyone here familiar with removing a PV6 bumper? Thanks...:wavey:
8 screw@nut only ...2 x screw left and right (end of bumper) 2 x size 10 (left and right below signal ; look from inside) and 4 x size 14 .. 2 left and 2 right (chasis)..
Hi idnawse,
Thank you for your reply! I found the 2 end of bumper screw but not the other 6 :banghead:
Will try again this weekend...thanks again :adore:
http://img90.imageshack.us/img90/3493/perdana.jpg
blue - 2 screw
red - 4 nut size 14 (2 each side)
yellow - 2 nut size 10 (1 each side)
u need to jack the car.. look from below, u can see the nut.
http://img171.imageshack.us/img171/6138/jgh.jpg
Thank you...you're a life saver...I'll try it out this weekend...
Nice lights...are those HID? I'm planning to do that too...:love:
Btw, any issues with JPJ so far?:hmmmm:
Ic...I plan to do bi-xenon projector with LED lights...
haha...very ambitious aren't i? cos the bumper also i dunno how to remove yet...hehe:listen:
Bi xenon means HID with Hi and Low beam...it is controlled via magnetic solenoid...when low beam, a shield blocks the lower half of the lense from the bulb
when high beam, a magnet pulls this shield down to expose the full lense to the bulb, hence light shines upwards...
:proud:
I tried it again yesterday...the 2 nuts beneath the indicator lights are so damn tight!!! probably i did not have the right tools...(i used the spanner from the emergency kit that came with the car)
Will get some proper tools and try again this weekend (long weekend)....hopefully I did not spoil the nut from my attempt yesterday...
where can i get that projector? and how much?
are you referring to my bi-xenon projectors? i got them new, about RM400+...you can get a used one here which are taken out from cars which have bi-xenon lights for about RM350.
Update: I've completed 1 side of my headlamp...tomorrow starting with the other headlamp :proud:
I know...it's a slow progress but I don't actually have much time to spend on it :bawling:
