diy: how to buka front wira bumper??
extreem
i hope cfu can help me la..how to open front wira bumper...standart one .i want do diy spray headlamp.
when i cabut skru headlamp the lamp can pull out.. it sangkut to my bumper.. now i want any one that know how to open it.
if can give me pic to open bumper....... i want spray headlamp ori wira to se ma.....
a forummer told me.. wira bumper got 2 main bracket/bone... u have to remove de bolts from below ur car then de whole bumper will come out together with de metal bracket... then u can remove de bumper from de bracket...
drexchan said:
you don't need to remove the bumper to remove the lamp lar.... open the nut from the fender..
i tried dat b4, but wasnt successful...
those 2 nuts near the signal lamp just dun 1 2 gif way...
huhhh.. afraid of straching the bumper...
i just drop the whole idea...
i have done ur project...u can refer to the project "spray headlamp"
DIY session...
like this,unscrue at the center....a little bit hard,then unscrue beside(have to open/pull out)the signal....(i lost my signal at this stage)then u scrue out the screw there...then slowly pull out the headlamp...a little bit hard coz it stuck with the bumper,but do it slowly.. ;)
i want the pic bumper
my bumper is not like wira biasa. wira 1999. it has like papan in the center bumper .i dont know how to open it.i was try to push headlamp out but my bumper rapat sangat and cannot out the lamp .i hope any body can send pic open bumper ..thanks
Hello, :D
I don't know mine same as yours or not. Mine Satria 98. "A" portion of the bolts are behind the bumper. You have to remove the number plate then stretch your hand inside to open these. "B" portion is at the tire side. All of them 7 bolts together. Good luck! :D
Did you mean the papan that holds the number plate?
The nuts are inside the bumper also. There are 2 nuts for each "papan". Remember to remove your number first. :D
