how to change sparks plugs
IceBikers
Hi, How to change wira se sparks plug as i did not do it b4...
just bought a tool set.. tot of checking out the condition of the plugs..
is it pull the hose/cable out n screw the plugs out?
what shud i see when the plug is taken out?
there should be a line on the middle of the tip
if the tip became round...its time to change
btw...what is the tool openner size to open the plug inside?
i got the screw driver to open the cover only...dunno the size for inside
errr... it comes with the tool set called "automotive tools set" - 60 pieces, i bought it a kuantan giant.. RM32.90
the tool size written there for spark plug is 5/8'' .. but i never try b4..
if the engine in question is 4G13/15, you'll need a 21mm "long" socket to remove the spark plugs.
4G9x series engines' spark plugs are slightly smaller, 16mm, if i'm not mistaken
pull of the high tension leads first, then unscrew the plug
cheers
