hondarians most problem...
orc3368
LEAKING...... why does the vtec switch area always leaks out the motor oil and why is the vtec switch seal always "putus"???? i really cannot stand it anymore spending rm60 every month just to buy that seal... and suggestions on how to overcome this problem????
i think it is the vtec solenoid seal. yes u can use back the seal but with gasket sealant.
common place for leaking is vtec solenoid, distributor o-ring, steering pump.
putus?
how can it be? unless the o-ring is squeezed tightly between the solenoid. or a "custom" o-ring?
chances of leaking is always there, but putus is something u need to be awared abt.
J101 said:
putus?
really bahhhh.... that thing really putus not custom seal.how can you make a custome seal where there is lots of bends...use sealant pun like no use few days only it be nice then back to it's normal problem..LEAKINGGGGGG......
