High Idling
cyfer
Hi Sifus,
My B16A idling is 1500. Dunno what happen, suddenly shoot up.
In addition, the engine check lit up when it happen.
Anyone got similar experience? Any solution?
Thanks.
must be a tube loose or not plug in...had similar prob few weeks ago...its a tube from ur engine to ur filter head there punya... dunno how to say... but sumtihng liek that la
kekeek
hope that helps
Hi bro.Check your vacumm line on the intake manifold area.What is the total blink of the light on your ecu?Good luck there.
Confirm is the air flow sensor. The connector is loose. After connecting it, it came off again when I drive around 120Kmh. Anyway to change the connector? Where could i get it permanently fix? Tks.
u can take out the connector and connect the wires directly into the opposite socket loh, if you dont want to waste time looking for the connector
