Idling problem
jingut_04
sifus,
I have an engine idling problem.The idling will drop to 300-400(300)when i'm using aircond.It will make my car feel vibrate from inside.I noticed that when the aircond fan is engaged.I f i'm only use a blower,the problem doesn't occur.could anybody advise me what sould i do?...is it because of aircond need service?...
Originally posted by jingut_04@Mar 23 2005, 09:02
sifus,
[snapback]832847[/snapback]​
Just tune ur car in Honda Service Center. They should tune it nicely for u. I think just need to adjust the RPM level when idle loh.
Originally posted by sasuke+Mar 23 2005, 09:19 -->
QUOTE(sasuke @ Mar 23 2005, 09:19 )
--QuoteBegin-jingut_04
@Mar 23 2005, 09:02
sifus,
[snapback]832908[/snapback]​
[/b][/quote]
Sasuke,
how much is the cost to tunning in Honda Service Center. My car also hv this problem same as Jinggut's car problem
tq
sifus,
jingut,
it might be caused by the EACV problem. You can try ask the mechanic to cuci for u in case the thing is full of dirt. this problem is common for honda. :)
sohc vtec hav to tune to higher rpm .. tune it to around 1.3k rpm.. when the engine gets hot.. it will stick at 900rpm.. when ya turn aircon on.. it will drop till 600~800 ... same thing happen to me.. when the first time the mech tune to 1.3k rpm.. i said u siao ar.. so high.. then he explain lo.. n it's true.. so hope u all try..
@Mar 23 2005, 09:02
sifus,
[/b][/quote]
yeahh... true true...
last time facing same problem n send my car to HSC to tune it...
until now no problem on idling... only still cannot be fast car.. :lol:
Originally posted by parimus+Mar 23 2005, 09:49 -->
QUOTE(parimus @ Mar 23 2005, 09:49 )
@Mar 23 2005, 09:02
sifus,
Sasuke,
tq
[snapback]832998[/snapback]​
[/b][/quote]
I think you can get it done for less than 100 provided u have no other problems lah. I always service my car in Osaka Puchong (next to Wei Yip Puchong, some where near Tesco). Their mechanic is all from HSC previously. Skillful and charge cheaper than HSC a bit. They have a computer device to tune ur car.
Originally posted by silver2002+Mar 23 2005, 10:02 -->
QUOTE(silver2002 @ Mar 23 2005, 10:02 )
@Mar 23 2005, 09:02
sifus,
jingut,
[snapback]833049[/snapback]​
[/b][/quote]
EAVC is what actually?
The service center ask me to clean my injectors. Any place can provide cheap and good service? They say need to be cleaned by special machine or something. They charge me 200+ for that.
Originally posted by sasuke+Mar 23 2005, 10:48 -->
QUOTE(sasuke @ Mar 23 2005, 10:48 )
@Mar 23 2005, 09:02
sifus,
jingut,
[snapback]833204[/snapback]​
[/b][/quote]
just wash it using tops... tak bau hapak... j/k oli.... :lol:
try to ask shop around sunway.. how much they can give u..
Originally posted by hattech-v+Mar 23 2005, 11:24 -->
QUOTE(hattech-v @ Mar 23 2005, 11:24 )
@Mar 23 2005, 09:02
sifus,
jingut,
[snapback]833290[/snapback]​
[/b][/quote]
Any shops u can recommend? :)
sifus,
bro..y dun u change ur idling valve 1st..
then clean da tro. body...just for RM50..
sure cun punya after this.. :D
Originally posted by Cimpeng+Mar 23 2005, 12:52 -->
QUOTE(Cimpeng @ Mar 23 2005, 12:52 )
@Mar 23 2005, 09:02
sifus,
[snapback]833576[/snapback]​
[/b][/quote]
RM50....which workshop????? reliable or not
sifus,
I kena twice before. The problem similar like yours, idling drop and the dashboard gegar abit WHEN i switched on the aircond only. only that my problem is with my aircond compressor. When was the last time you serviced your aircond? Have you changed your compressor within 3 years?
After changed to a new (recond ) compressor, problem solved.
Cheers
parimus..
y dun u ask mr. crower...RCT maybe...
cleaning for rm50
tuning for rm45
:D
eg8: how much for compressor air cond (recond)? :D
Originally posted by EG8+Mar 23 2005, 15:24 -->
QUOTE(EG8 @ Mar 23 2005, 15:24 )
@Mar 23 2005, 09:02
sifus,
Cheers
[snapback]834019[/snapback]​
[/quote]
eg8,
i dont think so...i changed my compressor twice...the idling problem still there......
:angry: so dont take risk to change compressor....expensive wooo
actually can just try using STP injectors cleaner...try em coz it wil help cleaning ur injectors out considering its not seriously clodded laa
Originally posted by parimus@Mar 23 2005, 16:37
eg8,
[snapback]834292[/snapback]​
I am not sure whats your car's problem actually is, mine solved when I changed the compressor.Now no more vibrate when i switched on the aircond, no more erratic idling.So consider problem solved.
Cimpeng
Rm280 siap pasang if your car is JDM. others i dunno la.avoid buying at chop shop, u might not know either the compressor still ok or not.price around rm140 at chop shop.at least buying at aircond man slightly expensive but i can get 3 months warranty..
just my 2 cents.
wow, u change your compressor so cheap ah?
mine i bought brand new from Honda. Cost me about RM1300 plus installation and aircond servicing.
