Help on checking ECU
Lame_ass
My friend got me a mitsubishi ecu for proton, how to check whether this ecu is working or not?
Is it safe to swap this ecu with my current ecu to determing whether my friend's ecu is working ? (the part no. is not the same)
What is the worst case that might occur if i swap an incompatible ecu?
Any help is greatly appreciated here.
hi,
for mmc ecu type, pls refer following link:
http://www.ftowa.com/html/workshop/workshopart07.html
locate the DLC pin#1, short it to ground (pin#4), turn into "ignition on" (but without starting the engine).
if ECU is gone, there is no blink at "engine check" lit.
could u give me the part number of your ecu?
my wira2001 1.3gli is 1400.
my freind wira1999 1.5gli is 1401.
both from apm.
it is safe to swap it with battery terminal removed....
adter u swap...put back d batery terminal n start...if can start..ecu ok...if car cannot star t...ecu kong or doenst suit ur car...my opinion
