HELP!!Jerking Satria GTI???
Joyride
My friend's GTI got a serious jerking at low RPM. The mechanic had serviced the throttle body, checked the ECU, sent the injectors for service, check plug cable, tested cylinder compression but still can find the problem.
This is the latest model with siemen ECU. No problem at high rev. Only jerking and engine stall during low speed cruising or when traffice is slow.
Any one out there come a cross problem like this?? Please advice....
Thanks!
the engine got die while dropping gears annot? mine does. from 3rd gear to 2nd gear, engine dies... at corner maut summore... lucky never bang divider.. -.-"
all i can say is.. SIEMENS IS THE BEST ECU IN THE WORLD!
I had the same problem - Water in petrol tank
I had the same problem. The mechanic checked everything. Even swapped the ignition coil and spark plugs with another car.
Last resort, checked the fuel filter. It was filled with water and mud and sand.
Then to confirm, my mechanic took out my petrol tank.. true enuff.. water and mud in the petrol tank.
After changing the petrol tank and fuel filter.. the jerking stopped at low rpm..but as soon as I reach 4500 rpm, the jerking started again.
So this time, took the injectors out for servicing. They found water in my injectors too. So after servicing the injectors, everything was fine. No more jerking.
try to unplug the battery cable so that MAYBE the ecu will forget the error,
from my experience it works!!!
NOTE : THIS MAYBE MY VERY OWN CASE. WELL, U HAVE NOTHING TO LOSE
BY UNPLUG THE CABLE N PLUG AGAIN.
Initial D,
Thank for sharing your experience. I tell my friend about it.
gggti,
Good idea and you are right. Nothing lose to try. Thanks.
I did ask him to change to MIVEC head. Solve the problem and can up grade too at the same time. But you know la... always is the M shortage...
hehe InitialD part-time rally driver :D
yup...... what u guys mentioned r possible things to check for
try checking the power TR unit as well (dunno if it's still being used on siemen ecu)
InitialD,
well i really wonder how sand, water even mud can b found inside ur fuel tank?? :confused: :confused: :confused:
How mud and sand and water got into my fuel tank?
Well.. it depends on which petrol station you go.
Some petrol station's underground tank might have a leak and water and soil might sip into the underground tank. Old petrol stations tend to experience this problem. So that's how the water and mud was found in my petrol tank.
Also try to avoid low lying petrol stations or avoid any petrol stations that have been thru a flood.
Also there are moisture in the petrol tank as our country is quite humid.
I lodged a complain and submitted a record of all the petrol stations that I frequent in the past 6 months. True enuff... I noticed they were digging up one of the petrol stations that was on my list. I guess they were patching up the crack in the tank or something.
Hi Joyride,
The symptoms that your friend has experienced is the same experience i went through before. the problem was with the speed sensor that is located behind the meter panel. it costs only RM25 and after having it replaced, no more jerking till today.
anyway mine is a 2001 MMC ECU SGTI. its worth having the speed sensor replaced first cos its the cheapest option and to my knowledge, the speed sensor for all SGTI's are the same including the SIEMENS model.
by the way, the speed sensor is available at any spare part shop, they are quite familliar with this.
cheers
RSGT,
Thanks for sharing your experience. The mechanic told him may be is valve leaking. Gotta re-grind valve. It's just only 3 years old car. And never modify. How come the valve can worn so quickly. Now my friend said when give a full trottle the engine then to take awhile to rev up and like got a little back fire too.
