help me pls...(temp high)
tank567
hai geng..
I got problem with my car temp..im using 1.6 vtec..
i had already changed my termostat..gasket but its still same..temp still high when i drive about 20 min or over the 100 km/j.....
any expert.?
please help me..i do know what to do..
Radiator look ok because air x kurang..the switch also changeg..is it my engine "kong" or something else..
any recomended mekanik..?can give me a numbe
tank567 said:
hai geng..
any expert.?
bro i had this problem but not as bad as urs, only during heavy usage like climbing genting will get this problem..
But now wat my mechanic he have done:
Tighten the torque, instead of using normal pipe water he flushed the radiator with 100 plus drink and now using only battery water for the radiator. Works fine.
No more overheating problem.
Hi bro,
Where is the location of workshop you send to doing this job, and also i don't understand when u said now using battery water in the radiator.As i know it is acid type,is it don't give any prob to the metal (radiator/engine)??...tq for ur info
vtec_ej6 said:
Hi bro,
bro, since mine is a 10 year old car already, the radiator water starts to rust ( by using normal pipe water) so by using battery water it does not rust anymore.
this mechanic is in cheras behind phoenix plaza. Very good in doing honda cars. Use to send the car to kah motor , one useless place to send !!
Hope it helps u as well...
Thank you bro..may be i will forward your thread to my friend currently having this temp prob.Anyway..may i know what is your ride type ef/eg/ek..?
best rgds..
best rgds..
mine is EJ6 SOCH VTEC
