wira 1.5 carb high temp
hello..
i got this problem..until now not setlle..need help..please!!!
my wira always had temp rising..many part have changed but still happened..
i've already changed water pump,thermostat,radiator hose,auto fan switch,coolant temp sensor..
i also do some servicing on radiator,doing flushing and wasted my coolant..
i found when the temp rising,the radiator fan not function(tak pusing)..after direct the wiring socket,it's function but can't stop..
are this is wiring problem?
tq all..
offcourse la when u direct the radiator fan it kept on spinning whenever u switch on your car key.....
i think u better go fine proper wireman first....
i think it might be your fan switch.. is there any wire going to the water inlet leading to the engine? there might be a switch there, that might be at fault..
