Helix DSP.2 / P SIX DSP
ICE -In Car Entertainment
Helix DSP.2
Brand New In Box
8 channels DSP with Burrbrown ADC/DAC, specification below
COD Location: Puchong, Seri Kembangan
Price: RM2000
Helix P SIX DSP
Brand New In Box
8 channels DSP with Burrbrown ADC/DAC and 6 channels amplifier
6x120W RMS @ 4ohm / 230W RMS @ 2ohm
Price: RM4900
whatsapp/call 012-2340244 to deal
DSP.2 Specification
Inputs
6 x RCA / Cinch
6 x Highlevel speaker input
1 x Optical SPDIF (12 - 96 kHz)
1 x Remote In
Input sensitivity RCA / Cinch 2 - 4 Volts
Highlevel 3.5 - 11 Volts
Outputs 8 x RCA / Cinch
1 x Remote Out
Output voltage 6 Volts
Frequency response 10 Hz - 22,000 Hz
DSP resolution 64 Bit
DSP power 295 MHz (1.2 billion MAC operations/second)
Sampling rate 48 kHz
DSP type Audio signal processor
Signal converters A/D: BurrBrown
D/A: BurrBrown
Signal-to-noise ratio digital input 112 dB (A-weighted)
Signal-to-noise ratio analog input 107 dB (A-weighted)
Total harmonic distortion (THD+N) digital input < 0.0008 %
Total harmonic distortion (THD+N) analog input < 0.002 %
IM distortion (IMD) digital input < 0.003 %
IM distortion (IMD) analog input < 0.005 %
Crosstalk > 90 dB
Operating voltage 9.6 - 18 Volts (max. 5 sec. down to 6 Volts)
Current draw < 480 mA
Max. remote output current 500 mA
Additional features HEC slot, Ground lift switch, Control Input,
ADEP circuit, Auto Remote switch
Dimensions (H x W x D) 40 x 177 x 120 mm /
1.58 x 6.97 x 4.72”
HELIX P SIX DSP SPECIFICATION
Output power RMS / max.
- @ 4 Ohms Channel A - F: 120 / 240 Watts per channel
- @ 2 Ohms Channel C - F: 230 / 460 Watts per channel
- @ 1 Ohm -
- bridged @ 4 Ohms -
- bridged @ 2 Ohms -
Amplifier technology Ultra HD Class D
Inputs 6 x RCA / Cinch
1 x Remote In
Input sensitivity RCA / Cinch 2 - 4 Volts or 4 - 8 Volts
Highlevel 5 - 10 Volts or 10 - 20 Volts
Input impedance RCA / Cinch 64 kOhms
Input impedance highlevel 13 Ohms oder 64 kOhms
Outputs 6 x Speaker output
2 x RCA / Cinch
2 x Remote Out
Output voltage RCA / Cinch 3 Volts RMS
Frequency response 20 Hz - 44,000 Hz
Sampling rate 96 kHz
D/A: BurrBrown
Signal-to-noise ratio digital input 105 dB (A-weighted)
Signal-to-noise ration analog input 100 dB (A-weighted)
Distortion (THD) < 0,008 %
Damping factor > 100
Operating voltage 10.5 - 32 Volts (max. 5 sec.down to 6 Volts)
Idle current 2200 mA
Fuse 3 x 20 A LP-Mini-fuse (APS)
Additional features HEC slot, ADEP circuit, Auto Remote switch, Control Input
Dimensions (H x W x D) 50 x 260 x 190 mm /
1.97 x 10.24 x 7.48“
