H22A Injectors
if H22A with resistor box, it should be 345cc/min peak hold. uses OBD-1
if H22A without resistor box, should be 295cc/min saturated. uses OBD-2. (I haven't seen this one yet in Malaysia, only the above.)
This one is from americans.. over here nobody actually has an injector flow rate tester.
