H22a injector on b18c
Burnz
hi to all vtec sifus here...i m currently using H22A injectors 330cc with e-manange on my b18c.So i m juz curious...since i use this injectors...izit necesarry to change a bigger fuel pump 2 match the injectors??
i confirm u get 2 rich at idle and very hard to tune at part throttle very rich
with just stock fuel pump good enough with running at 3 bar/42 psi
u only using 68% of the injector when at peak horse power or 7000 rpm
u might get 175-180 whp with everything was stock
ooh...so its fine that i use back my original so4 fuel pump then...cuz when i adjust my fuel regulator to 3 bar with h22a injector...during 7000rpm-7500rpm...i can feel it the rpm is heavy n have back fire...so i tune down around 2 bar..its juz fine...it can rev till 9000rpm smoothly.Thanks 4 ur info dcloo...cuz i saw many of the performance vtec go 4 borch fuel pump or sr20.That's y i m curious...
