mofano Junior Member Senior Member Apr 11, 2013 #1 Hello All Friend's , Can we used other grade of battery like DIN55 / DIN55R to replace the original DIN45R battery in gen2 cps. I need some helpful info here..TX Regard's Mofano
peeche Known Member Senior Member Apr 11, 2013 #2 no problem.. but make sure you check the space clearance 1st. afraid didn't clear the hood. ---------- Post added at 01:17 PM ---------- 6 hour anti-bump limit - Previous post was at 01:16 PM ---------- as i remember my spouse satria neo use DIN55 as stock battery.
E egb18c 500 RPM Senior Member Apr 11, 2013 #3 if can use din66 pun boleh.batt last longer with alot of amp for starting up the car. usually DIN model are much higher amp than NS model.
twistedichc 2,000 RPM Apr 11, 2013 #4 the batt i think still can fit but it's the base of the holder, might need to mod @ change
