GEN2 CPS Battery
mofano
Hello All Friend's ,
Can we used other grade of battery like DIN55 / DIN55R to replace the original DIN45R battery in gen2 cps. I need some helpful info here..TX
Regard's
Mofano
no problem.. but make sure you check the space clearance 1st. afraid didn't clear the hood.
---------- Post added at 01:17 PM ---------- 6 hour anti-bump limit - Previous post was at 01:16 PM ----------
as i remember my spouse satria neo use DIN55 as stock battery.
if can use din66 pun boleh.batt last longer with alot of amp for starting up the car.
usually DIN model are much higher amp than NS model.
