Gearbox noise
Zeroed
1,500 RPM
Hey guys. I could use some insight here.
My gearbox (4G93P) currently has some problems - it makes a "Shhhhihh" noise when you let go off the accelerator at revs above 3-4k rpm, when a gear is engaged. That is, when under engine deceleration. The gearbox is super smooth, the only problem is the noise. There is noise constantly as long as the gear is engaged under deceleration from high rpms.
Has anyone encountered this problem and fixed it before?
A member here, InitialD, suffers from the same problem with the same gearbox (same car model infact!)
I have never heard of this problem other than our cases before. Would greatly appreciate some input.
Thanks...
