Irritating Suspension Noises
ektony
Anyone knows a workshop that has got a shocks or suspension testing machine which will subject the vehicle to some vibration test to identify source of noise. The noise is coming from the rear only when going over uneven roads. Have tightened all visible bolts in the suspension set up. Also checked the rubber bushings. Shocks just one year old. Thanks
huakenny, spot on ! Decided to change the top rubber mounting. Noises gone. Inspected the original mounting , externally looks oK maybe the rubber already hardened. Thanks !
everyone failed to ask the right question..........what car are you driving? If the answer is a proton then problem cannot be fixed as it is part of the package hahahahaha
