Ferio 95-handling problem
miedeto
sorry because not post in english on the previous new thread..
i'm on behalf my friend having problem with his ferio 95'. in the beginning, his ferio have a chamber problem, so he went to press n burh the chamber.. then after that for a few months, his ferio always have to re-alignment... his tires went out(makan sebelah) from inside... then when he want to turn left, the steering not steer back to normal position like before.
went to workshop, but mechanics also dont know what to do.. ask other, some said chamber problem, some said lower arm, steering rack, some said install adjustable chamber kits..:confused::confused:
so somebody please help with suggestion n if have any workshop that can identify the real problem of his ferio.. (if have workshop in alor setar area or elsewhere)..:adore:
thanks guys in advance..
Replace bushings & change upper arms. Pressing the arm without replacing the bush will cause the camber to go out of wack again due to worn bushings.
