fender lamp
S1997
hi guys...any idea how to remove the fender lamp of wira? mine cover broken so want to replace with a new one.
thanks
I suppose u mean the signal blinker on the fender right? just open ur front door, after that, through the opening between door and fender, u will see the clip of the blinker, just use a long stick to give it a push then the blinker will drop out by itself.
well... there's another easier way to remove de lamp...
under de fender.. (above ur tyre) there is a plastic cover.. remove de screws so dat u can open a hole for ur hand to enter to push de clip n then de lamp is out...
signal lamp?
next to headlamp?
that one, find the stainless steel wire with a loop in the engine bay side, right behind the lamp.
to release : pull it, and pull it towards the side. This will unhook the stainless steel hook.
