Side Fender Kancil
trxx
how do i take off side fender kancil is it got 2 nuts?
then after removing got lots wires or not from it cause side have signal.
reason want to knock back fender dent . thanks gang
got 2 screw under the hood, there's another 2 at the gap between door and fender..1 below bumper, and u need to take out the protection plastic at ur tyre there about 5 / 6 puch button screw.
take out the signal first..then need to dissamble the socket only..no more wire
Before taking out the fender, make some marking on the fender and the car body. This is because when u put back the fender, alligning the fender back to the original position would be a nightmare. so make some marking....
i dun think the align for the fender is hard..when u install back, just make sure the gap between the bonnet and ur door are same as before..then u can screw it..it's easy for kancil
