Turbosmart FCD-1 (pneumatic)
Over Boost - Motorsports
Beyond 20,000 RPM!
WHEN DO YOU NEED A FUEL CUT DEFENDER?
Most late model cars have in-built defence mechanisms to guard against increases in boost pressure. Such systems are important, but can be an obstacle when increasing boost pressure and the performance of your turbocharged engine.
WHY BUY A TURBOSMART FCD?
Turbosmart FCDs provide a reliable and accurate increase in the factory fuel cut-out level. A Turbosmart FCD will allow boost pressure to be increased above the factory level and prevent momentary shutdown of the fuel injectors – hence maximising the factory turbo system.
Turbosmart Fuel Cut Defender range consists of FCD-1 a pneumatic controller and FCD-2 an electronic controller.
Description: The FCD-1 allows for an accurate increase in the factory fuel cut-out level without the need for cutting/splicing wires or affecting off-boost conditions. Suited to most turbo cars using a MAP sensor. The unit can be locked to prevent tampering.
APPLICATION: Suits most turbo cars. To be used in conjunction with a Turbosmart boost controller.
SUPPLIED WITH: Hose, fitting and a mounting bracket.
PRICE
Turbosmart FCD-1 (pneumatic) = RM 319.90
Over Boost - Motorsports are Authorized Dealer for Turbosmart Australia Products
http://www.overboost-motorsports.com/zthlogo.gif
CONTACT DETAILS
Address - No 28A, First Floor, Jalan PJS 11/7, Bandar Sunway, 46150, Petaling Jaya, Selangor, Malaysia (same row as N1 Racing, beside WRC Lighting)
E-Mail - [COLOR="Black"][email protected][/COLOR]
Tel - +603-5611 6628
Mobile - +6012-955 1800
Blackberry Pin - 2284DEF5
Website - OVER BOOST - MOTORSPORTS
MSN - [COLOR="black"][email protected][/COLOR]
Skype ID - overboost-motorsports
Facebook - Over Boost - Motorsports | Facebook
Mudah - PRO Niaga: Over Boost - Motorsports
CLICK HERE FOR CONTACT FORM
