Hi all sifus in here,
I have a problem with my evo 3 gearbox. When i decelerate, i can hear loud rattling noise from my gearbox. What is the source of it? Worn out gears? Can i service it to eradicate the noise?
If i need to change it, can anyone give me the model/serial number of an evo 3 gearbox. if i'm not mistaken it is W5M33 XXXX?
Why the final drive for evo 3 gearbox is said to be higher when it is 5.3 compared to evo 1 n 2 which is 5.4. I thought higher number means the ratio is higher as in the case of honda for example 4.7 is higher than 4.4
Lastly, if i replace my evo3 gearbox with an eclipse 2wd gearbox, would it help my acceleration or it will suffers. What is the pros and cons of having this gearbox compare with evo3 gearbox?
Thanks in advance.
Thanks in advance.
