Eterna NA AC problem
khairunizan
I've just finished transfer MT gearbox from my old Proton V6 to my New PV6 (Using full Eterna V6 NA halfcut, AT, Digital Aircon). After completing my Aircon won't working which is compressor not running (Before transfer it is functioning as well).
What i've already done to solve this problem is (which is done by AC foremen - 3 shop)
AC GAS - ok
compressor - ok (by pass)
AC Relay - ok
fuses - ok
AC switch - 4 kaki ok
Controller - ok (also plug in with another controller)
one more thing is angin AC also berterabur...
need help from you guys, thanks....:confused:
which compressor u running on? the perdana v6 compressor is piston type, eterna is rotary type......
that might be the problem.
thanks for your reply,
i'm not sure which type of compressor.. but i think this is because relay a/c not activated.. when i shorting the relay connection, the compressor will working...
it might be something which controlling the power to activate a/c relay..
do you know where is the power source to activate a/c relay??
AC GAS - ok
AC Relay - ok
fuses - ok
A/C foreman also cannot solve? You need to find A/C expert.....
Behind the aircon digital panel there is a tube.connect the tube hose.common problem for mitsubishi digital aircon.worth too try.
