Dynamic Engine Balancing Service
Dynamic Engine Balancing is a method used to eliminate vibration created by unequal centrifugal forces introduced during manufacture. These forces are usually a result of density irregularities in the parent material and/or machining eccentricities and can in many cases be equivalent to several times the crank's weight at rotational speed.
Why Dynamic Balance?
Imbalance greatly reduces bearing life, allows your engine to REV higher with Less Vibration to produce Higher Horsepower without damaging effects !!
**Crankshaft Assembly are Balanced to 10,000 rpm !!
Parts needed : Crankshaft, Flywheel, Clutch Cover, Damper / Crank Pulley Inc Timing Gears & Any Spacers ( Optional : Conrods, Pistons, Piston pin )
Price : rm750 Onwards..
Interested pls. pm or call : 017-3526055 (andy)
Dealing method : COD at Rev Performance @ No.7, Jln PJS 11/24, Bandar Sunway (1st Floor ) or Send by Postlaju.
Operating Hours : Monday to Saturday ( 11am - 7pm )
CLICK HERE to check out my other sales Item !!
