hampeh said:any one had tried?
diy turbo timer using microware timer?
try search for turbo timer manual. got wiring diagram inside so you will know how to connect or modified the wiring... ;)hampeh said:ya good idea washing machine timer!
ok,
if i wanna user the timer, which wire i should join?
i think i want put switch too.
if i want use the timer then i'll turn onn the switch.
or maybe some of you advance knowledge abot car circuit. maybe better join with the relay?
