DIY Microcompressor @ Mini Turbo
huakenny
LB Performance
This is kind of air booster, it keep extra air in the black thing....so when u revv,instead of sucking hard for fresh air.it wil easily get air from there. aftermarket air booster is way too expensive, so DIY is just ok for me.
Bigger size : http://i17.photobucket.com/albums/b95/huak...5airbooster.jpg
http://img166.imageshack.us/img166/9734/dsc00255airboosterrvs9.jpg
this is the basic setup for Mini Turbo, just connect between the PCV hose n connect with a 'tulang ikan'.....kawtim....the air u can adjust by twisting it.
Biggersize: http://i17.photobucket.com/albums/b95/huak...3basicsetup.jpg
http://img361.imageshack.us/img361/1866/dsc00253basicsetuprrr3.jpg
This is more advance setup....i connect to 4 intake ways for tat.....1 to PCV hose, 1 to air booster n another 2 direct to intake manifold...all of the hose connected to 'tulang ikan'
Bigger size : http://i17.photobucket.com/albums/b95/huak...253moderate.jpg
http://img222.imageshack.us/img222/4851/dsc00253moderaternu9.jpg
this will be the closer view of tat, u can see 4 hose connected to the 'tulang ikan'....the other end is connected to air breather.....to suck fresh air :)
Bigger Size: http://i17.photobucket.com/albums/b95/huakenny/DSC00256.jpg
http://img142.imageshack.us/img142/4189/dsc00256cffilterzl8.jpg
all items can be get from spare part shop, accesories shop n hardware shop. except the air booster...see the photo n identify the componets if u wish to DIY urself
GREAT!!!nice job.....all the thing in market is just a air bleed devices!!instead the air go through the TB or carb....just take another way to stuff extra air for the internal combustion.Engine is really like a big n huge vaccum pump!!but make sure your AFR doesnt too LEAN......when you xtra more air to the internal combustion....fuel also must take part of it....the ratio for it must be 14:1:1.....and this is optimum wan......where got..wan fast car...reduce fuel consumption.....if still wan it.....just set ur AFR LEAN lor......but for long term....not got for piston lor....n the engine too :X-:
Rule of Thumb!
1.Air-stuff more air inside the engine.
2.fuel-balance with the air for optimum mixture/ratio
3.Ignition-how big the spark wanna bang the mixture?
4.Timing-advanced or retard before TDC must be in good timing to get the power u wanna it.
this is just basic.
nice DIY bro. have few ideas for my bird to thanks to you. btw, how do you connect the air filter to the hose? as the air filter hole way too big for the hose. thanks. now im using temp air filter. ekeke...
as u seen closer to the photo....there is a adaptor (gold color)...can get it at hardware shop....:_:
jeremy said:
isn;t all 4 that the vacuum hoses? u just reroute alll the vacumm hose to the tulang ikan?
tulang ikan got 5 holes....4 holes for vacuum.1 to pcv hose, 1 to my air booster, 2 to intake directly...one for air breather
o..inside is empty?? izit vacuum inside o just a normal box..if just any normal box, how can it help? the air booster connect to wat besides the 1 pvc hose.
nice and neat diy. wan to diy the air booster too later. so far after installing the diy mini turbo, have experienced slight improvement on pick up. need to make it tidy soon.
hmm....try looks for Air Booster in the market n understand its function...
its too much for me to explain here....its just an empty box....
it make it easier for intake system to get air, instead of sucking directly from outside...it can get the air reserved in the box easily...
u unds? if stil not clear..try to goolge for more info, u should get the meaning soon
hehe
okok... thanks bro..i see a dyno jet/ at the background...i hav 1 installed in my ride too,,, no difference in fuel consumption watsoeva,, oni the rev drops slower everytime change gear..
tat i got it for free so just instal....to be frank...it is useless la:_:
