DIY Kancil brakelights
bigbug
When my brake pedal is depressed, none of the lights (including 3rd brake light)come on. When I switch on the lights, only one side lights up.
What should I open up to check for faults? :cyclops:
hey bro,
may i know that your dashbard got light when you turn on your headlamp??
if not,then check your bulbs....then socket....then fuse.just like what did khguan told you.but if your brake lamp burst,remember that change the bulb to 2 filements bulb.it's for brake lamp....
good luck.
frcgrey: Yup, dashboard still got lights. I will check the socket though, as khguan suggested.
But then, which fuse is for the brakelights?
