DIY install vacuum gauge for 08 vios
JasonKam
hi,
i decided to install a vacuum gauge for my toyota vios 08 model.engine kod is 1NZ-FE
i hv a few question here,hope u all can help me.....thx
1.) How to connect the wire? connect to where?(i mean-gauge backlight) red&black.
2.) Which vacuum hose should i connect to...?
there should be installation guide provided along with ur unit... as for where to connect the vacuum hose, find a vacuum hose which comes out from ur intake manifold... use a T-joint and tap from there...
Hi,
This should be a simple job, kindly open up your engine hood n start searching for the vacuum hose.. when u ram (press the fuel) u will the suction of the hose.. cut in the middle of the host and joint it with a t-socket 1st & 2nd joint to the actual vacuum hose & the 3rd joint it to your vacuum gauge. For your vaccum gauge u can juz simply tap the power (+) from any source e.g. fuse, lighter socket etc... the negative (-) terminal u can tap to your car body or earth or any nagative source.. done.. now when u ram (press the fuel) u will see the gauge meter moving and the light is on..
**note:- if u tap to ur car lighter power, your gauge will on when ever u start the engine.
- if u tap to battery terminal u better add in a fuse and switch.
- if u tap to fuse (e.g. small light power) then your gauge will function when u
switch on ur small light
....dieheartsue....
Hi,
Can anyone tell mi that using a reading 30inHG vaccum meter is better or 75cmHG meter is better?
And whats the diff?
Thanks for help guys
