DIY Boot Sound Deadening *pics*
DLegend
Official Contributor
Decided to sounddeaden my Waja's boot during this semester break..... I already plastered the floor of the Waja with Dynamat Extreme, so I have only RM150 left. Here goes....
Here are some pics to share:
Hope this helps anyone who wants to try to DIY :)
Materials:
1. SikaDamp360 x3 pieces (limited budget) RM105.00 (supplier :boeytan)
2. Insuflex (10mm x2) RM4x.00 (supplier :boeytan)
3. Scissors & Penknife
4. Dunlop CA Glue RM15 (big can)
5. Whiteboard marker pen
6. Old newspaper
7. Vacuum cleaner
8. Cold drinks RM3.00
Here are the materials used:
Silver pieces are SikaDamp630 & black mats are Insuflex
http://i8.photobucket.com/albums/a46/DLegend/Materials.jpg
First, strip the boot and vacuum it clean:
(Note the Dynamat Extreme that was left over from the floor project)
http://i8.photobucket.com/albums/a46/DLegend/Stripped.jpg
Next, I placed the SikaDamp where i wanted to cover (exhaust noise) & cut it to shape :
Remember to press it in place ( Use a heat source to soften the mat if required )
http://i8.photobucket.com/albums/a46/DLegend/CuttingAndShaping.jpg
Then, remove the backing paper and stick the SikaDamp to the surface with sufficient pressure:
http://i8.photobucket.com/albums/a46/DLegend/FirstLayerSika.jpg
Use the rest of the SikaDamp to cover the other important spots:
http://i8.photobucket.com/albums/a46/DLegend/Sikadone.jpg
After the SikaDamp's done, i used the old newspaper and drew out the shape to make templates for the Insuflex:
http://i8.photobucket.com/albums/a46/DLegend/Shaping.jpg
Then, cut the Insuflex according to the templates and apply Dunlop glue to the "rough" side of the mats and wait for the glue to harden slighty .... then STICK AWAY !!! :
http://i8.photobucket.com/albums/a46/DLegend/Biginsuflex.jpg
Here's when it's done:
( I left the higher portion un-matted because i'm gonna put my subbox there )
http://i8.photobucket.com/albums/a46/DLegend/Finish.jpg
Here are more pics of the Insuflex mats:
http://i8.photobucket.com/albums/a46/DLegend/LeftDone.jpg
Bootlid dampened also:
http://i8.photobucket.com/albums/a46/DLegend/TopBoot.jpg
Finally, i cut another piece of Insuflex just to lay it on top of the dampened boot ( just before putting the floorboards back - no glue )
http://i8.photobucket.com/albums/a46/DLegend/Final.jpg
Don't forget to clean up the mess after finishing :)
That's all for now, will do the doors next semester break.
Results:
1. Noticeable reduction in exhaust note intrusion
2. More pronounced noise coming from engine portion (more work to be done)
3. Whole car smells like glue for a week !!!
4. Subwoofer hits harder and deeper... not sure why.
Jay Jay.
isn't insuflex supposed to absorb sound? Have you tested your sub with and without the top sheet of insuflex? I've heard my friends car with and without it and with it the dynamat did a better job
Hahaa boeytan, i'm back in Nilai already.... nexttime lar... then u give me a few pieces of Dynamat... :) next semester break is during November.
Izso, the top layer is to reduce any other exhaust noise intrusions (hopefully) ... 'cause the waja's stock muffler is quite noisy already (noisy to me). The original floorboard is put on top of the top Insuflex, so doesn't make any difference in terms of the sub's wave reflections (sendiri blur adi....)
Anyway, i will post more pics once my custom sub box and new floorboard is done. :)
haha.. kidding bro.. i already dampen whole boot.... but maybe put another layer insulfex lar.
Hi cutypuppy, welcome to ZTH :)
I got the Insuflex from Boeytan, u can just click on his name and send him a message to get more info. Anyway, where are u located? If you're near KLIA, i have another spare piece of 10mm Insuflex with me.
izso,
are u comparing insulation material with dampenign material?? they work totally diff.. if u are playing with SQ bass.. then inslflex/or superlon would not be a go choice.. but for me... my boot superloned.. still find de bass nice to my ears...
if anyone from serdang wan insulflex... i have too... but have to let me know la... i dun keep much... rm15 for 6mm, rm20 for 10mm
