guys...mind to share here if you all got any info or experience before...
Is there any negative impact if we use different offset for our evo which still running with ori ACD/AYC system??? I mean same diameter and width but different offset...
Front : 18X9 offset +25 or +29
Rear : 18x9 offset +35
What the pros and cons???
...I know that is an advantage of this set up if on the track for some drivers...or maybe they all running mechanical LSD (ACD/AYC taken out...:hmmmm:)
This set up has being used by HKS on their CZ200S project...:rolleyes:
...I know that is an advantage of this set up if on the track for some drivers...or maybe they all running mechanical LSD (ACD/AYC taken out...:hmmmm:)This set up has being used by HKS on their CZ200S project...:rolleyes:
