suitable rims offset for eg
pok nik
i m looking for new 15" rims for my eg...can any1 here share some opinions about the most suitable offset for eg? is it 35, 42 or 45? i just can tell the difference of the measurement..why is it so and wat would be the problems faced if using rims with unsuitable offset as u mentioned?
uhmm.. i thought EGs had 45 Offset on the stock rims. Correct me if its wrong :). Anyways, if u want the most suitable offset.. stick with the stock one.
From wat i've read. Straying too far from the stock specs can spoil bearings and can mess with ur suspension geometry. Offset too low can also cause rubbing issues..especially if u use larger rims, cuz the rims will "push outside" from the hub towards the fender.
