Crv 2.0 High Temp..pls Help
vtec_ej6
For anybody has this problem before pls advice me..
My uncle's CRV got problem since last 2 weeks.The problem is the temperature is got high (red level) when in jam,but normal at straightaway.Send to mechanic also don't know what is the prob.For any body has face this prob before pls give some advice.The CRV 2.0 year 2001.Tq
crv overheating prob
both me & my fren experienced this before, could be one of two things (or both):
1. radiator leaking
2. cylinder head leaking
most likely its the 2nd option since ur mech cant seem to find wats wrong with it. good luck.
CRV high temp.
Thanxs for replies..
May i know how much the cost to fix the problem and which workshop is the best in KL valley..
Yong_5290 said:
yeap..mostly bcoz of radiator leak...if not fan is not working...
1st..when engine is running and temp. is up...see da fan. if fan not pusing..maybe motor fan is out..
2nd..if spare water at radiator is kering or kurang...maybe ur radiator head is leaking...
3rd..check if ur sensor switch for fan is ok.. :D
