Compression test
remove your spark plug, place the compression tester at the plug hole (meaning compression tester takes spark plug place) and crank the engine usually up to 5-6cranks to get reading. usually for turbo, anything lower than 8 should be considered "ada problem"...
ask your mechanic to do it for u. most probably they wont charge u for doing a compression test. u cant DIY unless u have the compression testing tool...
where to buy tat tool bro?
and if the compression found out is not match wit rhe maunufacturer's spec...wat kinds of problems the car is having a?:Not_Impressed:
lower than 8 got problem?something wrong wif the piston?
Air fuel ratio? Thanks. Also, do all mechs have the comp test tool cos i've never heard of mine mentioning such a thing! I really need a new mech!
not all mechs have the compression tester, but workshops which does modifications n really serious work should have them.
air fuel ratio sensor is a sensor which is plugged to ur exhaust, to know whether ur fuelling is enough or not. most tuners have it. its the definitive tool to get feedback on fuelling tuning...
Yeah, if it's too low, then you're losing compression somewhere. It could be that the piston rings are worn out. Or, a bad case would be your engine head is screwed, like in the case of my pal. It's probably due to detonation - the valve seat has a nick in it, so some fuel-air charge gets squeezed out from the nick during the compression stroke, leading to compression loss.
