compression ratio..come tell me
change to high comp pistons
use thinner head metal gasket
skim the cylinder head
increase the stroke of the motor
as higher the cr, the higher the possibilities of knock
when cr is increased, temperature of the mixture is raised high enough for it to self-ignite without the need of spark plug. when self ignition occur, higher than desirable pressure pulses are created which could damage the components. this audible phenomenon is called knock or ping.
pnp does not increase cr, it only smoothen the flow in the head ports. IMHO, it only affects at full throttle or with a high revolution motor.
Yeah when the temperature rises to the flash point, where it self-ignite thats what we call pinging or knocking and thats seriously a big nono..
thanks for the info....
so if i pnp my head will not effect the cr rite? any1 had done pnp? wonder how many % can pnp increase the power of the engine
something like that. :)
just a rule of thumb of increasing compression ratio,
every additional point increased will give approx 4% increase in power.
port and polish... not sure is it a good workmanship in Msia..???
In the overseas, they have specific CNC machine to grind and smoothens all intakes, valves etc. In Msia, i heard they do it BY HAND... mean grinding using sand papers etc. Each cyclinder must be balanced.. doing by hand with less precision, going to be balanceed????
Increase CR is good.. to avoid knocking, pls use high octane fuel.. but i heard our RON97 is good enough to cater around 12:1 CR. .. not sure tho.
C&C machine is the Command & Conquer machine.. hahaha.. no no jk only.
CNC is a computerised drilling and grinding machine.. very precise.. i forget what it means..
some ppl also called it NC machine..
If you have any idea what sort of programming that needs to go into a CNC machine for it to do all the stuff that's required for PnP, you'll understand why hand-porting is still a more realistic way of doing things.. besides, there are some parts of the engine head that might require flexible attachments (like the short side radius and further up the ports), and these areas may not be accessible to the tooling heads on CNC machines... and you'll need to finish off the job by hand anyway.
